On my iPhone 8, the speed sensor I have which is a Bontreger Interchange 238, paired with my Road Machine Classic Trainer the sensor is paired up, the correct trainer is selected.
When I attempt to load and start zwift, my rider doesn’t move & also my watts on screen (iPhone app or I also tried my wife’s Macbook Air… neither will show my rider moving.
I’m connected via ant+ I believe but possibly over Bluetooth.
In the pairing screen you showed I am seeing the trainer paired as the speed sensor, and the speed sensor paired as the cadence. If the Bontrager Interchange 238 is your speed sensor it should be paired as the speed sensor.
I went through the pairing you sensor help video on Zwift’s Youtube.
And it does the same thing there as it’s doing for me…
Under the Speed Sensor; it’s showing “Booster” and the Booster is his “classic trainer” and the Speed Sensor is the Bryton which he selects and that shows up under his Cadence Sensor.
Only thing that is different is that he has a Heart Rate Monitor as well paired. I have a new battery in it as well. The magnets on the cadence band & speed wheel sensor seem to communicating with the Bluetooth receiver.
My Bontrager Interchange Digital Combo Sensor does flicker “green” which indicates it’s paired.
But my Rider/Wattage still will not appear on either the iOS app or the Macbook Air Game.
