Install on new computer *error code ZL11*
Installing on a new PC. I’m getting a message that “Zwift is missing a required file”
tried reinstalling, same error
“Contact support with error code ZL11”
If I don’t close the popup window an update, I think it’s 1.1.16 downloads.
The launcher shortcut doesn’t get created.
I can go to the install file start Zwift with the launcher, however, only my Jetblack as a Power Source and a Cadence monitor connect as devices.
My Zwift Click 65A4 shows up under Contrrols, but won’t connect
The Jetblack doesn’t show up as a device under Resistance
are you sure it isn’t the Z117 error?
Very sure.
well you could try the things in the support doc I linked above and see if that helps?
new computer, so it likely has a bunch of bloatware installed, maybe something is blocking it?
No, this one is a clean build, not much more than Windows 11 and a couple of browsers I installed this morning.
When you re-installed, did you follow all the steps in this document?
Onedrive?
That document is for a reinstall on a machine that has previously run Zwift. Mine is clean I’ve uninstalled, and deleted the folders and done a reinstall (more than once) still get the same message
No, not on one drive, don’t use it. Prefer my data on my machines.
Are you running any sort of firewall? Or maybe the port Zwift wants to use is blocked by something else?
I have not tried to do a new reinstall, but other than updating my Nvidia drivers. I haven’t done anything different, and Zwift seems to be working now.:red_question_mark:
As written above this is a new build and I’ve gone through and checked for driver updates on everything, that seems to be the only thing that’s changed but it’s working
Hi @W_Fillingame
Shuji at Zwift HQ here.
Error ZL11 can indicate a corrupted or (on a brand new PC - missing) installation of a Windows component called Webview2..
Would you try downloading it before your try re-launching Zwift? This the direct link to the installer:
microsoft.com/fwlink/p/?LinkId=2124703
Would you let us know if this works on your brand new computer (or not)? TIA.
He already got it working (mentioned above).
I don’t think the driver updates were the reason so it remains unclear. There’s never a reason to update Nvidia drivers beyond the stable driver offered by Microsoft.
Also putting it here for the next person who searches for ZL11. :wink:
How could I get the cool free skins for my other games if I didn’t update the Nvidia driver? :slight_smile:
