Incorrect watt measurement (Elite Qubo Fluid + Misuro B+)
Hi there,
I am getting completely off watt numbers when using Zwift. I did a few test rides and did well above 300 watts on Zwift, while myETraining app gives a more realistic ~150 watts (I am averaging around 130 IRL).
Setup:
  • Trainer: New - Elite Qubo Fluid with Misuro B+ sensor
  • Misuro B+ sensor is set to 5 blinks
  • Device: Getting the same result on iphone and macOS too
  • Connection via bluetooth
  • Trainer connected as a power source and cadence source
Do you have any idea what the issue could be?
Thanks in advance!
Did you find the solution?
I get same issue:
Setup:
  • Trainer: New - Trubo muin smart B+ with Misuro B+ sensor
  • Misuro B+ sensor is set to 12 blinks
  • Device: Getting the same result on android and windows PC too
