Hello everyone
I have tried to setup Elite Qubo using Misuro B+ as sensor and I can select only as power source not as speed / cadence.
Using it as power source it does not detect any power as you can see in the screenshot.
Anyone is having the same compatibility issue?
Thanks a lot in advance!
Hi there, I have to same issue, I have tried using as an ANT with tyre size to use as a speed sensor, but when I do that it records my speed as over 75kph and I get in ride message telling me I am either an awesome cyclist or all the kit is set up wrong. Starting to think that swift is a big waste of time money and effort
It was my bad actually… I did not configure Misuro B+ properly, as explained in the instructions, it needs to be configured with 5 blinks for Elite Qubo Fluid. Then, the detection is decent.
However, now the issue is that I cannot adjust how it detects the power / speed - it detects the quite low speed and I cannot adjust in Zwift…
Same here! Zwift connects to Misuro B+ on a Qubo Fluid (yeah, five clicks) but shows a very low speed or no speed at all! Any ideas?
I just purchased an Elite Qubo Fluid and am wondering if I should also buy the Misuro B+ sensor for Zwift. Has anyone got this setup working in Zwift? I’m wondering if maybe I should just buy a speed/cadence sensor for use with Zwift. I think Zwift knows the power profile of the trainer, so can calculate power based on speed. Thoughts/opinions? Thanks in advance!
If you plan on racing send it back and get a smart trainer.
Old post. I am currently on vacation away from my smart trainer and I have here just the same combination with a borrowed bike that is too small. But au least it is something.
I face the same problems with the power to low.
But before that I had connection errors and was playing with the sensor position. At some point I had almost double the power. It was like the sensor got double triggering but also a lot of power on slow cadence.
Compared to the smart trainer it feels like it calculates/measures only 65% from the power.
I did not tried with the”primo" setting (setting 9). It looks similar. Maybe other power curves.
Did any one tested with 9? Also my device has FW version 18.
