Elite Roteo smart+ with Misuro+ sensor
have a new Elite Roteo+ in combination With a Misuro+ sensor.
it works with the elite app, but on Zwift the datas are horrible. Just crazy. Around 1600Watt…pls help.
thx,
tobi
Have you calibrated the Misuro+ sensor Tobi?
How can you calibrate? I have calibrated it by setting it to 14 blinks (as described in the manual of the Misuro B+)
Further, I have exactly the same issue. Elite Roteo, Misuro B+ sensor… nothing happens on Swift.
Please help!
Does the trainer/sensor operate OK with the My E-Training app?
Does Zwift detect the trainer/sensor, even if the numbers are not accurate?
If the trainer/sensor is detected which pairing option are you using.
I am not convinced the manual instruction for a set number of ‘blinks’ is correct for use with Zwift.
Reading past posts, Zwift are confident the Misuro B+ does operate OK with the correct configuration.
The funny thing is actually that the setup is working perfectly fine with Sufferfest (almost plug and play). But not with Zwift… Whatever I do, nothing seems to work on Zwift.
I’m gonna go have a look at Sufferfest’s set up see if I spot anything that can be related back to Zwift.
I am thinking configuring the sensor to behave as though the back wheel is on the bike running on a roller.
Probably incorrect but worth a look.
