Ride 27.8k for 1 hr but ride saved on Zwift as 10mins with 4k. Please log as bug.
I did Climb Portal- La Honda today and it shows correctly in zwift. However in Garmin connect, the activity shows as “Thio Virtual Cycling” from Zwift. The elevation seems to be off as a friend shows 1700 feet for La Honda while Thio show 1400 feet. It would be nice to get credit for the harder hill because it was a grind for me. Im running the latest and greatest of all the apps. Any one run into something like this before?
I did a 5v5 race recently and everyone had truncated activities in Companion. Correct in ZwiftPower though.
EDIT: after some time the Companion data was corrected. Check back later.
I saw this issue as well but it eventually was corrected. Check back later and see if it changes.
Thanks Paul, yes it has corrected itself. Thanks
Jill
Thanks Paul.
FYI, the reason these Climb Portal routes can be mis-labeled as “Thio Virtual Cycling” is because the IRL location that Zwift uses for the Climb Portals is in New Caledonia, and the nearest town to where these routes live is named “Thio”.
