Hi, anyone have a step by step to get a HRM resynced? I have a Garmin. It worked fine for a few years and now won’t. Still works fine with my bike Garmin so it is not the HRM. Everything else syncs fine. I have a Wahoo Kickr no issues there
Welcome to the forum.
Did you check that the HR monitor is ANT+ and Bluetooth. Most older Garmin HR monitors are ANT+ only.
For ATV you will need Bluetooth
We are having a similar issue but we use a Polar H7 HRM and after the last update won’t connect anymore, use to work fine now Zwift won’t recognize it.
I think is had to be Bluetooth since it did work fine for a few years.
Did you try to reset the HR monitor.
Also try a new battery.
Thanks, had to reset the HRM,… kind of odd that the latest update kicked out the HRM.
