Wahoo HR tickr not working so thought I’d give Garmin chest strap a try. In past there were issues re Ant+. At present will Garmin HRM work with Zwift and Apple TV? Any setup issues or extra hardware? Thanks!
ATV only uses Bluetooth, so if your Garmin strap is only ANT+ you won’t be able to use it unless you have some sort of BT/ANT+ bridge. I used a Garmin Dual with ATV and it works great.
