Hello,
I received my zwift ride today and have started riding in Watopia. I tried to familiarise myself with all the possible controls and then I had a question. To send a ‘Ride On’ to someone, it is possible, on PC, to click on name in the ‘Zwifters Nearby’ menu and send them a Ride On.
But I have Zwift Plays on my Zwift Ride, so I’d like to use them rather than using the touchpad on my laptop, but it doesn’t seem possible. Or at least I haven’t figured out how.
Is it possible to reach and navigate the ‘Zwifters Nearby’ menu using only the Zwift Play and not the mouse? And if so, how?
Pretty sure you cant with play controllers, but another way is using the companion app “zwifters nearby” list
Ok thanks a lot.
This confirms my first impression.
I will use the ZC app for that.
Thank you ![]()
press the z button on the right controller to send ride ons
Yes but it’s a ride on bomb (or a return ride bomb). You can not select someone and give a ride on specifically to him, or select his view or anything else you can do using your mouse and interact with the nearby zwifters
