Getting to main menu from Zwift play controller
Hello. I can’t find any recent information about getting to game menu direct from Zwift play controller. Example would be if wanting to change bike mid ride or ending a ride when finished. I’m just wanting to see if I can avoid the Apple TV controller or the companion menu bar. Thanks
I press B and that allows me to select the menu button by pressing A.
From there you can navigate to your garage.
Thanks for the info. Is that how you shut down a ride race as well if you don’t mind me asking
Not sure what you mean by shutdown. Pressing B is how I get the menu or end risk buttons (if in a group ride/race). That will either take you to the menu to end ride or get you out of the race/group ride and just in a free ride.
Hi @Seymore_Vanleuven, welcome to Forums! I’m Francisco from Zwift Support.
Good question! If you’re using Zwift Play controllers, you can access the in-game menu by trying the following:
  • Press B → This brings up the menu where you can navigate with A to select options.
  • From there, you can access your garage , change your bike, or end your ride.
  • If you’re in a group ride or race, pressing B will also show the option to leave the event or continue as a free ride.
I hope that helps! Let us know if you need more details check this article: Using Your Zwift Play in the section: Navigating the UI.
