Change default selection one quick menu
Can the behaviour be changed where the default option when you press up on the zwift play controllers goes to u turn? I have had a few times now where I make it so when I press up it is on emoji and then I can quickly give a ride on to someone. But if I don’t do it for a while it switched to a u turn. So I could be quite far into my route. Go to give someone a ride on but where I just go UP A A I have done a u turn and then I do another to get back to the original direction but I have lost visible progress of how far along my route I am. I have finished the route but was sure I was going to until I got there.
Why aren’t you just pressing the Z button to give Ride Ons?
Just want to make sure you are aware of this document…
Let me know if you have any questions about it
because I want the little picture to pop up and the vocals!
I had a read through that and not sure if that helps me.
Thanks.
