Help me
Hi well cheesed off with Zwift
Signed up to do my first race today at 20.10 I clicked on the race I had entered 5 min before the start, I was then taken to all the categories and I clicked on the category I had entered nothing happened.
There was nothing else to click on to get to the start.
By the time I had messed about the race had already started well p***ed off.
What do I need to do to get to the start line thanks
Did you enter a world and start riding before the start of the race? There will be a “join now” button on the bottom left of the screen that then takes you to the start pens of the race.
At the bottom of that window, you may need to scroll down, there is a “start ride” button that takes you right into the start pens. Sounds like you missed that step.
I wasn’t in a world I warmed up just on my trainer then clicked on the ride which was on the events page at the start of Zwift.
I didn’t see any join now under the category section
Those are the two ways to join an event, i bet you just didnt scroll down far enough in the event tile/pop up window.
as Mike says you need to scroll down below where the categories are there should of been a start ride/join now button.
or the other way join any guest world and it appears in bottom left to join the event.
For events you you can join the pen from 30 mins before the start time. So if you are not seeing a join button i would suggest either join a guest world or restart zwift asap.
