Hello, Any Help would be great, I just switched from trainer road to zwift. I did the free trial period and everything worked fine until the last 2 k of free time, then it went to almost a free spin where the most i could do do is 50 watts in my 53x11 at 120rpm. I assumed it was just that my trial was ending. So i signed up and on the very first ride it started fine and then quit controlling the resistance, I loaded the latest firm ware and claibrated my trainer and started over, It worked for about 2k then as soon as i topped a little hill and it went down hill it never added resistance again.
Please help, Zwift customer support has not answered my email.
Funny , I’m new to this forum as of this morning because I experienced a similar problem on my morning ride. Resistance totally our of sync with the difficulty of the route. Spinning in a high gear, mashing in a low gear. My cadence measurements also went blank from time to time. I’ve been using Zwift with no problems since November. How do I determine if “firmware updates” are the problem?
the same thing happens to me, I have a flux2 tacxs and I stop controlling the resistance, the technical support center doesn’t answer me !!! the only thing I could investigate is that you have to paired in a controllable way or restart it several times to make it work
Once advance settings is checked, go to the “update firmware” section, let the trainer sync up and update. I believe they are now on firmware 31.062.
I’m having a similar issue with my Hammer H1 on Zwift, resistance is now just constant no matter the gradient. Last season it worked perfectly, now when I get to a hill it does not change the resistance. Going downhill it does seem to work a little by reducing the resistance ever so slightly. I have tried both my PC with an ANT setup and an Apple tablet using Bluetooth, having the same results. (Blue LED is solid and I have the trainer setting set to max in setup) Any thoughts?
Right, I have it set to the max. It’s interesting that on a large negative grade of -10% I can feel it easier to pedal, but that is the only time I can tell a change in resistance. I use to have to shift gears all the time, now I never have to
Ok, I figured out my issue. What had me thinking was it worked (resistance changed) when I went down a steep hill. Turns out I had a wrong power supply plugged in to the Hammer. With the correct one I now have the amps to give me resistance going up a grade. Appreciate the help Gerrie!
