Hello I just purchased the garmin vector 3 pedals and they do not seem to be working in zwift properly. They do show up in the pairing screen. These pedals are dual and not just the single side. I am connecting Bluetooth. I also am connecting my tacx neo 2 and my heart rate monitor via Bluetooth. I am using the power meter for cadence and power and the neo 2 as controllable. Once I start the ride it takes a while to start moving although I am pedaling. If I stop pedaling the avatar rolls off and does not stop moving even though I stopped pedaling. It makes no sense.
With this setup do I need to connect ant +? I am on a MacBook Pro. Please help!
Lastly, you can get an ANT+ dogle for your MacBook and try connecting via that instead of Bluetooth. The first time you pair, it will probably show up as “Powermeter XXX” but after the first session, it’ll change to “Garmin PWR.”
Thank you for the quick response. Attached are some pictures. I have ordered the tacx ant+ adapter. Can you tell by the picture if I have the original or new design for the battery cover?
