I’ve been trying to pair my new garmin vector 3 pedals to zwift iOS via Bluetooth unsuccessfully. I’ve started restarted, opened different things in different orders, and ensured no other devices are picking up the vectors signal.
I had a chance to look into this further and it appears that Zwift currently only support Vector pedals (including the Vector 3) via ANT+. FWIW, it is stated in their FAQ as such.
Following up again, there is a firmware update on the way for the Vector 3 that will enable Bluetooth for Zwift and other apps. Expect to see it in early December.
Thanks to DCR and Trainer Road for providing that very useful info.
Just checking in as well with the same concern (in case Garmin cares). I’m hopeful that they will get the bluetooth working on Vector 3s. Fingers crossed for an update…
Pretty lame of Garmin not to have this sorted or at least an update seeing as we spend a lot of money on these devices!!
I gave up in the end and bought an ant+ dongle for zwift which seems to work really well!
Like Ben, I finally ended up getting an ant+ dongle as well, which works okay for zwift. HOWEVER, I’ll be very disappointed once the snow melts and I can get outside if I still can’t get data from these Vectors via BLE (I use Strava on an iPhone along with a Wahoo RFLKT, no ant+ connectivity). Not really a Zwift problem, but I’m hoping that Garmin will see this and do something!
Magnus as far as I know, there aren’t any ANT+ dongles for iPhone 5 or newer, and that’s the problem. For winter I’m connecting the Vectors to Zwift via a ANT+ dongle on my laptop, but come spring time I really hope Garmin has a fix in place.
Latest newsis that we are looking at February for a Garmin firmware update.
Until Garmin release a Vector 3 firmware update that enables Bluetooth for Zwift and other apps, here is how you can use the pedals with a newer iOS device.
A. Use a ANT+ to Bluetooth bridge
(Note: I have not used this approach, but others have done so sucessfully)
