Thanks that fixed it
I finished the über pretzel 2 weeks ago, but didnāt get the badge after completion. After the update, I noticed the route badge was added now, but unfortunately the ābonus xpā wasnāt credited to my profileā¦
Updated this morning, I can join Events (through Companion and the PC app) but I do not get a notification that they are starting when cycling and as a consequence I cannot actually join the ride/race/TT. have reset filters, rebooted PC.
Reading here this update looks to be riddled with bugs. poor testing by the looks
Anyone know if the gradient map is fixed in London? iām guessing not but I live in hope!
Zwift App for Windows 10 stability issues since this update, not always able to connect on mixed connectors. Either external connectors (HR belt & Cadence meter) XOR either Smart Trainer, but not both selections possible anymore. Testing done on Zwift Android & Wahoo extrernal connectors (with Wahoo Elemnt) working, no problems. So seems windows Zwift app or Companion? Is this a known issue? Thx for help, hopefully before Academies start.
With the new update the application closes suddenly when passing through the finish line in a race. Anyone else with the same problem?
I feared that would be the case.
Am I the only one that finds it really annoying and makes me avoid the London routes? I use that graph all the time to see what gradient changes are coming up for gear choices and things.
I first raised it at the start of May, it is in the known issues section and it used to work fine and works on all other worlds, it seems like a really easy fix and is really really annoying!
Considering the way the gradient map āworksā in the first place, Iād be surprised if it ever gets fixed. This was designed by someone who has never seen a gradient nor a map.
Yeah but the Baby on Board workouts!
On the pacer bots, see Pace Partners FAQ [August 2020] - #194
First sessions since update: lost connection 4 times in a 1 hour session. Yeah⦠not cool.
depending on what device you use for Zwift, you should check your log file in zwiftalizer.com and see if that helps narrow down why you lost connection. I did a large group ride last night and had no issues on windows 10 with ant+.
Bin gerade Uber Pretzel gefahren. Trotz Update kein Abzeichen. ![]()
Thanks Gerrie. Works like a charm!!
Anyone else lose drops? I lost my drops earnt from my last ride - activity saved and uploaded just lost all the drops
Hello,
Yesterday a colleague and I connected from Spain to the race āDCU Iagttagelseslob powered by Feltet.dkā at the end, and waiting for the classification, the application closed (crashed).
zwift updated with windows 10.
Do you know what the cause may be?
Hi all,
maybe itās a coincidence but iāve just finished my first session after the update and my Elite Sterzo has not worked fine.
It keeps on reconnecting and disconnecting even if nothing in my setup has changed since iāve bought the sterzo (from zwift shop about 1 months ago).
Every other device is working fine (trainer, HRM and so on).
This device is ANT+ too but zwift not support it yetā¦is the support comin?
@Wes Has the Pace Partners scheduled down time changed? I was online at usual time but no Partners were available
