Quite a few reports of rides crashing on apple tv since the last update. Will the latest update resolve this problem?
Like persistent crashes after Alpe du Zwift - the game goes into a âhangâ on AppleTV, people claim they can flick out and back into the app to get it to work - not the best experience, for sure.
Thanks @Wes, you guys are a lifesaver!
âŠalthough things seemed to have sorted themselves out at my end ![]()
Tim
Why are there no specific posts for these small updates? Not easy to find their patch notesâŠ
Itâs edited into the OP.
After update patch of 11/29th, I had the first crash ever (2y)
Win10 with intel i7
Crashed 1h into the run workout and never recovered. All progress lost. Running on Makuri
I didnât know that, but that is still inappropriate I think. The topic name is still âGame Update - November 18th, 2021â and the updates 1.19.1 and 1.19.2 were NOT on the 18th November 2021.
To be honest it is beyond me why there is no page with patch notes like other games have. See Counter-Strike: Global Offensive » Updates for example. All the updates separate and in reverse chronological order.
Since Nov updates I cannot use Zwift on ATV (now 1.19.2) because ZCA (3.30.0) running on iPAD Air pairs bluetooth connections then immediately displays âno signalâ⊠Supposedly a known issue w/o remedy.
What devices are you trying to connect? Can you connect (at least two of them) directly through ATV?
Running a Stages SB20 & Garmin HRM -Connections found but as mentioned immediately showing âno signalâ.
Iâve seen that on Windows 10 also for Bluetooth. I spent some time trying to get the Bluetooth connection to work, but though the devices were discovered I never got any data. In my case it didnât matter as I use ANT+ (which works) so I didnât spend a lot of time trying to figure it out.
But are you pairing your devices directly to Zwift through the ATV, or through Companion? The wording of your original post indicates you are pairing through ZCA, so I am wondering if pairing directly to the Zwift app will correct the issue. If you already connecting directly Iâm not sure what else to try.
Iâm pairing through ZCA because you only get two devices through Zwift w/ ATV. I have atleast three w/ the trainer, HRM, & ATV remote.
That would all work through the ATV. The ATV has 3 BT connections, but one is always used by the remote, leaving only two available. So, you can still connect your trainer and HRM directly through the ATV at the same time.
Itâ a new banner, appeared in Nov update.
I often saw it. But with this little patch from âRussian Hackersâ (checked with 100133 and 100145) - no more âConnection Disconnectedâ appears. hxxps://forums.zwift.com/t/connection-disconnected-banner/564289/6
I am using Zwift on Android. This latest Update that you forced on me totally broke the game for. me. When I am doing a workout, the power that I need to produce lags about a minute behind what I am told to produce by the workout. I tried it with multiple workouts and restarted / rebooted multiple times. This is really super annoying. Please read this and fix this asap.
Hello,
I add version 1.0.52 and it does not update to the new version (on Windows) also, I get and TLS security error and the lancher does not work.
Please, I need your help to solve this.
The TLS error means your launcher is still out of date. Close Zwift from the system tray, get the latest installer from Download Zwift on iOS, MAC, PC, or Android Devices | Zwift and run it. There should be no need to reinstall the whole game, but if it still doesnât work youâll have to choice but to do so.
After three days in a row trying to get this working again, I finally gave up on Zwift. At least for now. I tried more or less every variation that was available to me. Trying it on Windows. Removing all other apps that would possible interfere with the Bluetooth / ANT+ connection. Turning of all other Bluetooth Devices - even my headphones. I did not yet kick my Kickr, but soon would have.
Instead I installed Wahoo SYSTM. And it just works. It even connects with my Fenix6 watch as a HRM - that never worked reliably with Zwift. No weird and random power surges/drops anymore. This is such a relief - I already started to question my own mental sanity.
