Game Update - March 16th, 2021
You sure the button isnt stuck down due to the hood slipping? Its a known issue\quirk of the Atom.
I’m also having this problem. Dumb trainer, garmin speed and cadence sensors. Tried on windows 10 and Android phone. Same on both. Huge power numbers and not even pedalling hard. Actually started one route at 310w!!!
What is this bug? And are you sure it’s a Zwift bug? Zwift should only be showing the power that is transmitted by your trainer/power meter, unless you’re using a dumb trainer and ‘Z Power’, in which case Zwift estimates your power, but requires that you set up your trainer correctly.
Interesting, Thanks for the tip. I just checked, and everything loaded up just fine this morning. I’m not sure what changed since last night but i’ll clear the cache anyway.
Thanks for the tip will check this/ The gears are working fine within the Wattbike app which makes me think it is Zwift related.
Going to try connecting via a Windows pc to see if behaviour is the same
Here to report the same problem as a ride leader. Two ride crashes when having the yellow beacon, both happening when I was trying to type using a keyboard. This is very frustrating to say the least. Will stick with companion app for the next ride.
In this mornings KISS at Base Training Ride (C) I was suddenly thrown out of the group after 4 kilometers. 2 minutes behind, all alone. No love for today’s upgrade so far.:frowning:
Good afternoon! After updating the program, there was a problem. Zwift began to overestimate the virtual power. All sensors are connected in the same way, the machine is configured as before, but the program outputs much higher power, which does not correspond to reality. What can I do?
Yes, i have the same… And don’t know what to do…
Just checked on Windows platform and gearing is working. Seems to be an issue on Android app.
Hi. Updates seems to have changed gear settings.
I have my WattBike Atom set to 11 gear ratios, yet on today’s ride the ratios had changed to 22 throwing my regular cadence and power levels against usual rides.
I’ve checked WattBike Hub and my gear settings are correct.
Using iPad Pro / iOS running the new Zwift update.
I mean it is all those sad saps have I guess…
Iv been saying this for a while. Some class D group rides I participate in have flyers easily hitting 1-1.5x W/KG over the group guide speed. Also being class D some of the newbie riders aren’t strong enough yet to complete the ride and are dropped which must be discouraging for them.
Hi, glad to see the updates, no mention of a fix to the issue Zwift has with Intel Iris graphics drivers that have been causing Zwift to freeze mid game at alarmingly frequent times since a previous update. Zwift was running fine until earlier in the year. New bikes and kit are great but if Zwift won’t run properly, you can’t complete an event etc and it is a problem. We are told Zwift are working on a fix, and have been for some time, any news on when it will be please?
Power ratio from speed and cadence sensor has changed since the update?
Is this a recent known issue?
Ios app says that after riding a route and closing, one can select a nee route without exiting/closing zwift.
Tried on Windows: still exits the game.
Tried on Ios: one can indeed select a new route without leaving zwift.
Bug partially fixed? Yes i did reinstall on windows after the update…
I have the same problem. Much higher virtual power output from speed and cadence sensor.
Same issue here. Already spoken to support and he mentioned it may be an update bug…wish updates were optional!!
Because of that bug I lost my first 7 weeks of Build me Up.
How can I now start in week 8 or 9?
I don’t want to do it all over agian and start in the beginning
Hi Kris and Konsti,
Please can you send your crash logs into our support team details how to do so are here:
PC or MAC
If on a mobile device or ATV please see here for how to locate.
This will help us investigate.
Thank you!
