Game Update - January 21st, 2021
That’s a limitation on Apple TV, so a Zwift update won’t have changed that. However, some devices can share a connection - e.g. a trainer can typically send cadence and power down one connection.
No, I’m a ride leader and there is no kick option or button.
How would this work? Use the red buttons as the steerer?
Any chance of pace partners doing different route. Why can’t Coco go over hills? I’m a Cat C I’m not going Cat B just to get some hills.
I to am waiting for this !
Coco does sometimes go through Titan’s Grove. If you ride w/her daily or often enough, she’ll drag you over the hill. How often? I don’t know. Is it on set days? I don’t know. But I do know that she will alter the route occasionally to go over the climb vs only looping the desert.
Why not make an effort on not having to restart Zwift to make an other race or take on another course?
I believe that to be the most wanted feature of all!
Hello. I’m using at the most five bikes. So I’d like to reduce the devices in garage and the numbers of jerseys either. Dito wheels. At events would be good to have a decision I want to have the unlocked jersey in the garage or not😜
Totally with you on this, when are Zwift going to sort this, the Sterzo Smart is ANT compatible so why aren’t Zwift making it useable after promoting the product???
Oh … please, end the Sticky Draft. It is desperate to climb the Alpe du Zwift at 4.0w/kg and get stuck behind a user at 2.0w/kg and fail to overtake him
Sad to see no support for the SB20 bike and steering.
Is this a Zwift or Stages issue?
Same with NeoBike & WattBike. I assume they just focused on getting one right first - also it may need some work from the manufacturers. Ideally they would release the connectivity guidelines and then we can put the pressure on Stages/Tacx instead of Zwift.
From the comments DCR has made in the past, the onus certainly isn’t on the bike manufacturers. I’m paraphrasing here but if anything they’ve been left frustrated by Zwift’s inaction on using features they’ve had ready to go from launch.
We had a local diy TTT event with multiple separate meetups that have all crashed and file corrupted at the end after this new update.
The Zwift companion app keeps disconnecting during rides, its on and off all the time
Yes Tempus Fugit is really boring …
If you’re using the companion app you will see your friends on the map you’re currently on. It looks like the Google drop pin…
Hope this helps.
So frustrating!!
Can’t get anywhere on my iPad, kicker snap shows no signal, Assioma duos show no signal, and wahoo ticker won’t connect at all.
Further testing shows the Zwift Bluetooth icon in the top left resetting a couple of times on the pairing screen, works fine on iPhone 11 so seems an iPad specific issue.
Same here! No signal on everthing( wattbike atom) and after restart it can’t find the bike. IPad Pro.
