Game Update Dec 2019
Please help i want to train but zwift doesn’t want respond
BETA ANT+ Heartrate strap support on Android (more device support to come in next update)
haaaaaaaa llelujah
waiting for power ANT+ support!
Have to report that the distance bug has not been fixed properly.
Big Foot Hills race today. Even from the start, it was obvious that the distance was 7 km off. It stayed like that all the way to the finish.
Except… with 0 km to go (or 7 rather) distance jumped to 3300 m and counted down. Then it jumped up again to 2000 m… and once more to 2000.
Anyway… ZwiftPower has the distances correct, so it is possible. I can only advise everyone to use ZP for distance, until Zwift manages to fix it properly.
When is the game actually updated. Been in today and haven’t noticed the missions or any update?
Nice👍
I have had some trouble with the ERG-mode with my Wahoo Kickr 2018, actually with both of them. -And yes, i have done the calibration correctly several times.
Hope you get my message, even though my English isn’t too well.
The problem is the ERG-mode. While my cadence is stabile, the roller always give more resistance downhill than uphill. It also tend to be slow to react to accelerations. In certain moments i am shure (Garmin Vector pedals confirms) i am putting in a lot more watts than shown on the screen.
I get that there may be a delay, but the watts dont seem to rise more than one or two watts at all. Even though my vector pedals show up to 30 watts more. This usually lasts for up to five seconds before the roller reacts by giving less resitsance. However the extra watts i pulled never got registred.
To make it clear, it seems to me like the ERG-mode is incapable of registering watts in different levels than the amount of watts it is supposed to give, and when it realises the resistance is wrong, it adjusts, but without giving credit for the extra watt i have been pushing for some seconds.
For your information my rollers have been connected by the companion app (Bluetooth).
Hope this can be fixed, or you can suggest what i am doing wrong.
Best regards
Ole Andreas
If you’re on Windows, MacOS or Android it should be available right now. If you’re on Android you might have to go to Google Play and update, depending on your update settings. Windows and MacOS should automatically update.
iOS (iPad etc.) and AppleTV will be available in the next few days or so - they’re systems take a bit longer to process updates I believe.
That would be a way to monetize, but I goes against Zwift’s mission: to get you to ride more.
I hope not.
why the bkool smart pro 2 dont works
You did not fix the event distance bug. It is as bad as ever. Route today was Big Foot Hills, distance was wrong throughout and changed several times in the last few km. I can only assume this wasn’t tested at all as it’s obvious from the moment you start. Yet Zwiftpower gets this correct?
This is great news.
Can I expect to use a HRM strap like Wahoo Tickr X with running on Zwift?
It does include speed with HR so technically it should be all one needs but it did not work previously for me on Bluetooth.
Pleeeeease:
  1. Choose a new world or route without having to shut down and restart the game
  2. Real PRs not just last 30 days.
Same here. Did the 100k ZHR Audax Ride today. Route was waistband and the distances on top and on the right were off.
But good job in fixing the turn signs!!
Isn’t this by design? The right side (and +XP) is actual distance ridden including the lead-in, and the top panel is distance into the current event.
Thanks for the update. Tacx 2T fixed, but not the brandnew Tacx Neo Bike Smart… :frowning_woman:
No Road Feel for Neo Bike Smart
Is this correct or do I miss something?
Greetings,
I’ve been riding with Zwift for almost a year now and love it! Was really excited about the off road offerings and got everything I needed to be able to steer. Unfortunately, I have the Kickr set up in my garage building which is out of the range of the Wi-Fi. Therefore, I have to use the hotspot on my phone to use Zwift. I have not found a way to use the phone for steering while it is being used as a hotspot. Apparently, a large number of Zwifters have this issue. I’m glad you are working on other ways to steer the bike. I’m hoping this may overcome our issue.
Thanks,
Scott
Hi There,
A quick question and request for support if I may…
After your recent updates Bluetooth (built in the Asus Zenbook Windows 10 laptop 2019) has no longer works. Up until these updates I used to connect all necessary Wahoo sensors and using the laptop own built in Bluetooth connection without ANT+ extension or adapter.
Now laptop does recognize all 3 Wahoo sensors (heartrate, speed, cadence) but when you’d like to start your ride avatar does not move. Only heartrate does show something. Speed does appear or doesn’t but nothing of cadence.
Via iPad does work as before even after recent updates.
Thank you to your advice, prompt help.
Kind Rgds,
Laszlo
If you’re using iPhone as hotspot it’s by design (it’s called client isolation) and there’s no way around it.
Hey zwift team, feel free to insert the possibility to pause the workout plan, this should be pretty easy to do and we pay not only for ride and race, but also for training, and this has been asked I don’t know how many time from such a big group of people here.
Before adding new bikes, roads, animations shouldn’t be more useful to give to users real training options? as well as change route or ride without exit from the program…
Thank you for this update but you need to fix the 45kg minimum this is « broken » kids are your most sensitive clients and futur zwifter.
Imagine not being able to use all the key on your keyboard … let’s say the A E O Y U I my message would look like :
Thnk y fr ths pdt bt y nd to fx th 45kg mnmm ths s « brkn » kds r yr mst snstv clnts nd ftr zwftr.
Imgne nt bng bl t s ll th k n yr kbrd … lt’s sy th my mssg wld lk lk :
That’s how they feel on Zwift. Fix the broken stuff first please.
Thank you
