Game Update - April 29th, 2020
What’s with all the top speeds!? I’m seeing that too with Apple TV
100% my experience
Thanks Zwift, amazing work as usual. Any news on an update to allow use of the Samsung Galaxy TAB A for Zwifting. It still remains a highly popular tablet, but sadly is STILL incompatible with Zwift :disappointed_relieved:
Zwift.
In hour house we use 2 Wahoo kickrs , 2 Wahoo tickrs and 2 Zwift footpods on an Apple TV & other iOS devices.
We find it very inconvenient trying to connect the heart rate monitor or footpod each time as we have to take out the batteries on everything we aren’t using, isn’t there a way that Zwift could let us select the bluetooth connection we want and unconnected the bluetooth connection we don’t want to use at that time without having to remove the batteries every time.
Hey steve, I use a kickr too but my cadence/power/controllable is all in one bluetooth connection, I use the other for my HRM so I don’t need to use the companion app to have all 4 connected. Isn’t yours the same?
Please could we have a fix for the god awful Apple TV remote problems. Surely it’s the most miserable piece of tech ever invented! It never selects what you want it to select, the cursor won’t move where you want it to move. That’s meant group rides/workouts that I finish will be stopped and saved when I actually want to keep riding! There’s also an issue with Apple TV 4K and the sound suddenly stopping which means I have to restart the app (it’s not my internet connection speed, I have the fastest fibre internet available in my country) Thanks for the work you do, keep it up!
Regarding this latest update, I would like to point out that the “dates” in the workouts you’ve finished are a bit screwed up. I mean particularly the year, which are replaced by long numbers that doesn’t make any sense. Pls fix this asap. Thanks.
Hi
Have you been informed of any power problems after the update? My watts surged over 1200w in my first race after the update. Had to stop the race as it was all to easy and I was putting out 9.#w/kg easily. This only after the update.
Since the Update i cant Login to zwift. It doesnt work with my Smartphone and with my Laptop.
I’m using Zwift since 4 months without any problem on my Samsung S9+ and Samsung Tablet S4.
Today I updated to 49821 and cannot login anymore. Pls solve that issue asap.
Same for me. Good to know rhat I am not alone, but sad situation on a bank holiday. I planned a longer ride for today.
Same here… now I’m thinking about riding outside in rain and windy conditions :frowning:
Bei mir geht seit dem Update gar nichts mehr. Auch über Hotspot vom Handy keine Chance.
Hey Jodie - thank for replying - I have a Wahoo Kickr with a Wahoo Cadence sensor on the Crank shaft - so my connections are used up as follows:
  1. Power / Controllable (ATV)
  2. HRM (ATV)
  3. Cadence Sensor (Requires Companion)
Maybe I’m doing something wrong with the Cadence sensor?
Any thoughts?
Do a firmware update on the Kickr, and you can get (estimated) cadence via the Kickr
The ATV can only handle 2 BT Connection next to the remote as 3rd connection… so the firmware update to the kickr should be the solution
ErG wouldn’t work ever since the update. Can someone advise how to fix?
Hey, the login does not work after the update release!!!
Awesome - thank you, Ben!
That cadence fix is only for kickr18 and core or newer by the way. If something has changed recently it’s probably a bug.
