fwiw, related to your experience on a Direto, I think there’s been a past feature request for Zwift to reduce the wattage threshold (ie increase to eg 50 watts or somesuch) for enabling supertuck. Not sure if that’s still being looked at.
I think if Power is zero or the cadence is zero and the wattage is dropping (or below a limit) for X seconds that could be a good workaround
Supertuck fine today on ATV here when with PP.
Back pedal a few times sometimes gets it to kick in quicker
Cool, thanks.
That only works with a pedal- or crank-based power meter, doesn’t it? A trainer can’t tell that your back-pedalling, but a power meter can.
I find it drops the cadence quicker which then allows the super tuck to start…
I’ve used it on both kickr & atom…
Looks like that helped. ‘Tis a wonderment.
I’m using Wahoo Kickr smart trainer V5, after the latest update my trainer started doing strange things -the power sometimes increase and decrease not inline with resistance… Sometimes when going downhill the resistance increases, not sure if this something to do with zwift or wahoo…
This has been happening to wahoo users for ages and zwift don’t seem to care.
I swapped my kickr17 for a v5 because it was constantly having power issues with zwift.
This is sometimes related to the firmware version you are using with the Kickr. Can you clarify you are running the latest version?
Did anyone else lose items from their garage when they updated? (couple of jerseys earned recently, Laser Bullet helmet from the Alpe I
got ages ago etc)
I’m not sure about the jerseys, but I seem to recall a thread from a while back saying that the Lazer helmet from the Alpe had changed colors. So, you might still have it, but it may be all white now.
The black/red Lazer Bullet helmet was overwritten with a white Lazer Vento.
I am having same issue with tacx
Establish the Bluetooth connections. Start ride then get
Connection failure
Never had any problems previously but now happening 2 nights on the trot
Thank you for adding the new pace partners!
Bluetooth connection failures? or Internet connection failures?
What platform are you on? Windows, iPad, iOS, Android, etc.?
Hi. Apple TV 4K gen 2 running latest updates. Trouble seemed to start with the recent Apple TV update
If it’s Bluetooth issues, not sure what to tell you since I’m also on Apple TV 4K (1st gen). I’ve never had any Bluetooth issues whatsoever. I have always paired my trainer and HRM directly to the AppleTV. You recently move your setup around changing the distance between the Apple TV and trainer or their position relative to each other?
If it’s internet disconnections, check your local network. Move wifi to 5Ghz if available. Try an ethernet cable for testing purposes. Reboot your router and/or wifi equipment.
Aside from updating Zwift, make sure Apple tvOS is updated as well. I think the latest update was about a week ago.
Hi everything worked flawlessly for months. Until the recent Apple TV update. Might reset every connection and see if more resilient
Not changed anything distanced. All within a couple of meters of each other
Other strange items is that it will keep connection my Garmin watch for HR. But drop the ones to the sensors in the tacx ( which is 5 months old). I have Also checked that it’s running Latest firmware too
