Yeah, for some reason it worked the day after the errors. Haven’t tried again since though.
Yes, especially along the route where these colorful trucks are parked.
Thanks very much, I did try that several times. Moving to a different wifi network seemed to be what solved the problem. Not sure why.
Zwift sent me the following email. I did not have to do the following but will keep in mind in future. Maybe will help someone else with this issue.
Thanks for reaching out to us! My name is Emilia and I’m a Support Specialist at Zwift. I’m sorry for your problem with Zwift, but I’m happy to assist you.
The z117 error indicates that Zwift is unable to create or write to your Downloads folder.
For more info on why this might be happening, check out our article:
(forum post won’t let me include link)
Once you’ve gone through that checklist, let us know if they apply or not, and we’ll go from there.
(Link says this)
Error Code: z117
Issue Summary
This error indicates Zwift is having difficulty writing in the Documents folder on your computer. Here’s some of the reasons this may happen:
- You are not an Admin on your machine.
- Another program on your computer is interfering with Zwift.
- You have less than 4GB of free space on your hard drive.
Workaround
These are a couple possible workarounds:
- Right-click on the ZwiftInstaller file and choose ‘Run as Admin…’ even if you already have Admin access on your computer.
- If you have an antivirus program installed, make sure it’s not preventing Zwift from writing to your account folder.
- If you have a sync program (e.g. Dropbox, Microsoft OneDrive) installed, make sure it’s not syncing your Documents folder.
- Make sure your default Documents folder is accessible.
If the Documents folder is saved to a disconnected network drive, it may not be accessible.
- If the workarounds above don’t work, try deleting the Zwift folder under Documents , and then re-launching Zwift.
For more info, check out this link on our forums.
Tested the Neokyo Flat route with pace partner ride… no frame rate drops. Tomorrow i will do my workout on the same route.
Yesterday I did the workout Kirizuma on the Neokyo flat route.
The extreme frame rate drops always occur shortly before leaving the park and then last for at least a minute… and always at this point for each round.
BTW. Tested with ATV (current model) and Companion App on iPhone.
Since updates I have a hard time joining a pace partner as usually drops me in Downtown but not with group. Thought I saw someplace that there was a bug but to retry but often even after three tries I just give up. A few times I did end up with a group my avatar went a different route so lost the bot. Using iPad so iOS. Like there are more choices but if cannot connect up consistently it is frustrating.
Hi @Tony_Konvalin_SFuels, this is a known issue. @James_Zwift is working on it!
Update v.1.25.2 has been released. It fixed the two issues below:
Thanks - just wanted to make sure it was known
Does it also address Bologna which had the same issue?
It does, we verified.
Nice one, thanks.
Small typo. Your message says “Update v1.25.1 has been released”. I believe it should be “Update v.1.25.2 has been released”
Indeed. Thanks for calling it out.
I noticed that riding with D Drops and D Duke today the pace partner increases their w/kg by 0.2w/kg riding uphill.
Can you provide details on this? Is the increase 0.2w/kg across all pace partners? At what % grade does this kick in? Anything else interesting we should know?
This post shows the PP routes for next week, but discusses the dynamic pacing to which you are referring, which is also discussed on other threads about the PPs:
Shuji: I just ran Splash & Dash (6.2 km) today in an Adidas RFTO 2022 event and earned only 20 XP bonus for route completion. All other Zwift runs of comparable length earn 200-225 XP bonus. I chatted with Zwift support, and they verified there were no glitches or drops with my run and confirmed Splash & Dash badge only earns 20 XP bonus. Is this an error, as it appears to be a super low XP bonus?
Big discrepancies in all the running routes tbh (see here). Odd.
1.25 or 1.25.1 may have broken supertuck for Apple TV.
Because I use an Elite Direto II, which reports power until the flywheel stops, supertucking is always an adventure. For the past couple of weeks, it’s become impossible. Regardless of speed, gradient or power output, my avatar will not go into supertuck and I’m well and conclusively dropped by teammates who do go into supertuck.
I thought this was a personal issue - perhaps trainer resistance - but a teammate on our Thursday TTT team reports the same issue. He’s also on Apple TV but a different trainer.
On the positive side, 1.25.2 fixed the white Tron wheel glitch.
Any other reports.
The XP you’ve been awarded is correct but yes i agree it’s exceptionally low considering you can earn 15 HP per quarter of a mile.
