A post was merged into an existing topic: White tron bike
Having issues when trying to run. Always connect via companion and it wonât work it sees my stryd but then doesnât actually run
Using Apple TV 4K 2021
It might not be related but we are having a similar issue with Stryd. We have two Strydâs and Zwift used to list both so we could pick the correct one (they were listed with a number e.g. âStryd 001â, âStryd 002â, etc.). Recently the number has been removed from the list and just a single Stryd is listed so often it picks up the wrong one and avatar wonât move. Only solution weâve found it to move the other Stryd out of range.
I was also having issue with the heart monitor. After 30 mins of randomly trying everything it worked but the companion screen remained blank either way it connected my stryd and HR to the Apple TV so I didnât touch it and completed my run so maybe a companion issue?
Meetups and joining late. This is still buggy and canât join within the 30mins. Either it wonât find the group or you ride in the sky (glitches).
Had the same bouncy pack dynamics and failure to correctly save/upload issue yesterday (Apple TV) on London (as well as graphical glitches) today did an event on a Yorkshire circuit and there seemed to be no such issues and immediately after the update did Classics in NYC no issues. It kind of feels like these issues being reported are limited to particular worlds/courses?
Signed up for Roval Climbing Challenge in Companion App.
Started Zwifting.
No join event button appeared.
Quit Zwift.
Double checked I was signed up in Companion.
Tried again.
Still no join button.
Switched everything off at mains.
Tried again.
Still no join button appeared.
âŚDid a free ride
Apple TV 4K 2017
Kish, Iâm on MacOS 11.4 with no crashes at the moâŚwhatâs happening?
Iâll also add that I had constant crashes a while ago, and despite it being a high spec Mac, that i run pretty intense programmes on, Zwift was the only thing to crash it. Now, hereâs a word of warning as unfortunately, it appears that Zwift crashing was a warning that my Logic board was dying (and like i mentioned, i use heavy programmes every day for my work)âŚI wonât go into further details, but the crashing got worse, started to affect everything and once my logic board was replaced, all the zwift crashing stopped (well, except for the message bug).
So to summrise, watch out for your logic board if Zwift is the only thing crashingâŚhopefully itâs not that, but just throwing it out there.
I have exactly the same problem . No issue with Zwift previously . Today when I clicked on Zwift , was asked to update . Right after update I couldnât use both my Assioma pedal power meter as power source and T300 as controllable ⌠Well , cancelling Zwift subscription
Same here on Apple TV
The in game sound remains running clipping/failing in Android 10 Galaxy Tab A7 2020. It runs fine in my Android 9 Moto G6 Plus.
My usually reliable STRYD foot pod will no longer reliably connect to ZWIFT Run via Apple TV OR the companion app. My Wahoo arm HRM is having the same issues. It took me twenty minutes to actually connect both this morning and thirty minutes into a run the STRYD disconnected and now neither will reconnect. I have already made sure one hundred times over that they are not connected to any other Bluetooth devices.
Getting out of Zwift until problem is solve
Husband said he noticed this same thing this morning.
Anyone else having the problem the 4iiii powermeter cadance sensor not connecting to Zwift anymore?
See Also : Canât pair both Controllable and Power signals separately [1.15.0]
it is part of the bigger problem for some,âŚlike me also with a 4iiii
See the âCrash after update: âUnexpected Errorâ on Macâ thread in Zwift Forums under Bugs and Support sub-forum. Its a well-documented issue on MacOS that Zwift is not acknowledging exists.
Couldnât join event after update. Join event button was there, I quit Zwift to recalibrate trainer but when I came back no way to join the event I signed up for. Restarting app didnât help, I see even on main screen on top right but when I click ride I donât get option to join event.
Yes exactly the same here,only records first ride and not second on ATV.
