Game randomly minimizes on screen
 Windows 10 Pro (Latest updates)
In game the screen minimizes to the task bar randomly  – usually results in my having to stop to get the game back on the screen. Occurs during races and is most frustrating. Thanks for helping
You probably run Zwift fullscreen, and there is some other program (maybe not even one with a visible window), which periodically activates itself and thereby forces Zwift to be visible only in the taskbar.
The easiest solution is to change Zwift to run in window mode (change it under settings). You can maximise the window, or alternatively use Borderless Gaming , which can remove the border around the Zwift window so it looks just the same as in fullscreen mode.
