Some more feedback,
I did the Zwift HQ Steering race last weekend and must say it’s really great.
Once you have learned the skills it’s not so difficult to get back in draft. (in this race was almost everyone with the unit,…i guess)
With some good steering technic it’s also a (little bit) more easy to close a gap if you are dropped a few seconds as you can see in my stream. https://www.twitch.tv/videos/711080563 (sorry only 720p)
I did also already an event lead with the sterzo , and a wtrl ttt , not any issues for me
Big win: Finally free from Sticky Draft !!
About the unit, it’s solid , very good quality.
EDIT August 21: The tension problem below is solved because i did use the unit upside down.
The Triangle should point up and not down
̶O̶n̶e̶ ̶n̶o̶t̶i̶o̶n̶,̶ ̶t̶h̶e̶ ̶z̶e̶r̶o̶ ̶c̶e̶n̶t̶e̶r̶ ̶s̶p̶r̶i̶n̶g̶ ̶i̶s̶ ̶m̶a̶y̶b̶e̶ ̶a̶ ̶l̶i̶t̶t̶l̶e̶ ̶b̶i̶t̶ ̶t̶o̶ ̶s̶t̶r̶o̶n̶g̶ ̶f̶o̶r̶ ̶a̶ ̶l̶i̶g̶h̶t̶w̶e̶i̶g̶h̶t̶ ̶a̶s̶ ̶m̶e̶,̶
̶i̶f̶ ̶i̶ ̶d̶o̶ ̶a̶ ̶f̶u̶l̶l̶ ̶u̶n̶i̶t̶ ̶t̶u̶r̶n̶,̶ ̶t̶h̶e̶ ̶w̶h̶o̶l̶e̶ ̶u̶n̶i̶t̶ ̶i̶s̶ ̶s̶l̶i̶p̶p̶i̶n̶g̶ ̶a̶w̶a̶y̶,̶ ̶o̶n̶ ̶t̶h̶e̶ ̶f̶l̶o̶o̶r̶ ̶,̶ ̶t̶r̶a̶i̶n̶e̶r̶m̶a̶t̶ ̶o̶r̶ ̶n̶o̶t̶,̶ ̶i̶t̶ ̶s̶l̶i̶p̶s̶,̶
̶h̶o̶w̶e̶v̶e̶r̶,̶ ̶y̶o̶u̶ ̶d̶o̶n̶’̶t̶ ̶n̶e̶e̶d̶ ̶t̶o̶ ̶t̶u̶r̶n̶ ̶v̶e̶r̶y̶ ̶m̶u̶c̶h̶ ̶t̶o̶ ̶m̶a̶k̶e̶ ̶y̶o̶u̶r̶ ̶a̶v̶a̶t̶a̶r̶ ̶s̶t̶e̶e̶r̶i̶n̶g̶ ̶f̶a̶s̶t̶,̶ ̶s̶o̶ ̶i̶ ̶c̶a̶n̶ ̶l̶e̶t̶ ̶t̶h̶e̶ ̶u̶n̶i̶t̶ ̶s̶t̶a̶y̶ ̶i̶n̶ ̶p̶o̶s̶i̶t̶i̶o̶n̶ ̶o̶n̶ ̶t̶h̶e̶ ̶g̶r̶o̶u̶n̶d̶.̶
̶W̶o̶u̶l̶d̶ ̶b̶e̶ ̶b̶e̶t̶t̶e̶r̶ ̶i̶f̶ ̶w̶e̶ ̶c̶a̶n̶ ̶a̶d̶j̶u̶s̶t̶ ̶t̶h̶e̶ ̶s̶p̶r̶i̶n̶g̶.̶ ̶M̶a̶y̶b̶e̶ ̶i̶t̶ ̶w̶i̶l̶l̶ ̶l̶o̶o̶s̶e̶ ̶s̶o̶m̶e̶ ̶t̶e̶n̶s̶i̶o̶n̶ ̶w̶h̶e̶n̶ ̶m̶o̶r̶e̶ ̶u̶s̶i̶n̶g̶ ̶i̶t̶.̶
Cheers
