Ftp results are too high
@Gerrie_Delport_ODZ
I use Bluetooth to connect.
But the blue light for ANT+ flashes de hole time.
Can this be the problem?
Are you sure the trainer does not connect to another device that has ANT+.
I would guess blinking Blue light is waiting for Bluetooth connection.
I would suggest contacting Elite, I don’t have a Elite trainer so I don’t know the light pattern.
@Gerrie_Delport_ODZ
I do get always a pop-up’ would you remove ant+ running because it can block you’re ant+’
I choose voor ‘yes’
But I don’t use ant+ only bleutooth
If you are not using ANT+ then just unplug it from the PC.
Or are you referring to the Garmin software, I would uninstall the Garmin software if that is the message.
@Gerrie_Delport_ODZ
This is the pop-up
Uninstall Garmin Express if you don’t use it.
If you do use it go to the windows settings and make sure it does not start when you start the PC.
