Hello,
Just bought Elite Zumo and have been trying everything to get ERG mode working (game controls trainer power). I’m able to connecto to the meter with mobile/pad with bluetooth, but resistance does not change accordingly.
If I connect to the trainer with ant+ via Elites own software and control the resistance manually, zwift does seem to get the correct numbers.
Have tried to reboot/reconnect all devices multiple times in different order. Also tried installing the game to pad/mobile. Tried to change all possible settings from Elites own trainer app, but zwift still doesn’t seem to be able to control the resistance. I did successfully update Zumo firmware, without help to this issue.
Whats next, any tips or is this a known problem?
same here - a few others have the same problem too so think it is a problem with the zumo- zwift have said it is an unsupported trainer apparently
Is there a source where Zwift says so?
I specifically bought a trainer to play Zwift, because it looks entertaining (as indoor cycling can be). Made sure everything should work:
it works on everything except android I believe - if you have a PC and Ant+ you’re good to go
Hi. I had the same problem. I could control the trainer from my Garmin computer and via MyEtrainer app on my android phone. But no resistance on zwift running on my PC. I then bought a cheap ANT+ dongle from china (CYCPLUS). Now I could connect my powermeter and the zumo trainer directly, but I still could not get zwift to control the trainer. I thought that maybe the ANT+ dongle did not have the right functions, so i bought a new ANT+ dongle from Elite. This solved all my problems.
