If I understand correctly, this will automatically switch off I. Workout mode and on otherwise?
I hope so because I can’t find the darn button to turn it on/off
The ERG button is on the companion app and on the bottom on screen menu.
If you want to do a workout wit ERG completely off you can select ERG off in the workout menu.
I must be blind….any chance I could get a screen shot? I’ve deleted and downloaded the app, etc and can’t find it in either app or on computer ![]()
this should be stickied on the front page for sure
I do not have that option. ![]()
The Erg on/off does not show up on my menu bar. Everything else is the same …
I’m using a new Zwift Hub. Does that make any difference?
Thank You
Thank you so much. ![]()
I knew it had to be something simple, I was probably trying too hard !
Best Regards,
Dan
Happy you got it working. ![]()
