Having issues my the watts that are being displayed. It started off with fluctuating power readings (low end and jumping up 50 watts in a second ) now I hit 2000 watts(!) by pedaling lightly.
Wow @Doro_Fuller_F3_Racin, you are strong ![]()
Welcome to the forums. I think the first thing you should try is a full power cycle of your equipment, then maybe use the Elite app to calibrate the trainer and try again.
have you calibrated it via the myetraining elite software? Might just need calibrating correctly
Thanks, this is probably what the issue is!
hello sir chris
I have the same problem, how did you fix this?
Pull up a chair and have a read…
