I’m basically using 2 devices for my ZWIFT. A macbook and a pc. In my Macbook, I created a custom workout but everytime I login using my PC, I don’t see that workout in my list.
I thought it was saved under my profile?
Is it not?
Is it not?
The custom workout files (.zwo) are kept in your documents folder on the PC locally. Look under /documents then /zwift then /workouts. I assume that they are also stored an apple device in a similar way, so as long as the files are .zwo they should be compatible between devices and you would need to copy them over to use.
Hope that helps.
