I am using DirCon on a Wahoo KICKR V5, Zwift V1.123. I have returned to Zwift after Summer, cannot get Zwift and Wahoo to talk. Last season it was Rock Solid. The programs see each other and the connections are made, Equipment Ready Symbol comes up on the Home Screen, but I will not record any cadence or power, therefore won’t work. I am really frustrated as I have little time for workouts as it is and I have now spent nearly 6 sessions resetting, power down and up, complete waste of time. Any ideas anyone?
Shut down Zwift, run the Wahoo app, do a test ride there. Do you get watts or cadence in the Wahoo app?
Thanks Paul, I shut everything down, including the Network, Bluetooth and ANT dongles on the PC and rebuilt it as follows: Router, Modem, Switch, PC - then booted up Zwift. Once Zwift was alive, I connected the Kickr via DirCon and once it could be seen on the Zwift connections page spun for a few minutes. I did see the Kickr to some degree, basically saying I had 33 Watts and 50 RPM - It was more like 130 Watts at 90RPM. Switched on the Blutooth, ANT and then Garmin Head Unit and loaded the Session. Session did start, but I was pushing more like 200 Watts, cadence was correct, but the Power was way off. After 4 minutes the Kickr calibrated itself, shot up to 600 watts, dropped to zero and then settled down after about 30 seconds - there after all OK.
Does this sound like a Kickr problem to you or connectivity issue, bearing in mind the connection has always been there - just not reading the data. Massive hypothetical question I know - just wondering if you had experience here. Many thanks,
The best way to establish that the trainer is OK is to test it in the Wahoo app. This would tell you if your next step is to talk to Wahoo, or maintain focus on the PC. I believe if you talk to Wahoo support, that’s what they will ask you to do.
Hi Paul, did the test as suggested and Wahoo was not reading at all on the phone App. Read somewhere about taking the cover off and giving the Optical Sensor a clean, I didn’t have a Torque Key small enough. Next best thing gave the wheel house and electronics a good blast of compressed air. Never seen so much dust come out of the thing. Left it alone for an hour, jumped back on and connected first time. Case solved with a good blasting of Air to clean dust and detritus collected over a couple of years.
