"Connection failure" error message at mid-ride
It seems to persistently happen around 20 minutes into a ride, I get the message connection failure, I go to the pairing menu and everything connects, I go back to the ride and I get the message connection failure, I go to the pairing menu and everything connects, I go back to the ride and I get the message connection failure, I go to the pairing menu and everything connects, I go back to the ride…
Eventually after 3-8 attempts it’ll stay connected, or I get sick of it, unpair everything and then pair again.
I switch bluetooth, wifi and mobile data off on my phone to minimise interference. Garmin Kickr core doesn’t have this problem with Rouvey or the Garmin app itself, and the fact that everything connects and shows power, speed cadence etc in the pairing menu leads me to think this is an issue with Zwift and nothing else.
The same problem, especially when I was climbing hard and found that the connection failed…
Are you losing data transfer at this time. Ie. No watts, cadence etc? Does your HR also go?
I switch my pair from WIFI to BLE and it backs to normal.
@Andrew_Jones8 @GAOFENG_LI, you can find the most common causes and workarounds for this type of issue here: Connection Error Messages
Thanks Martha, my issue is fixed!
I’ve gone through that document thoroughly and it makes no difference, I could be 10 minutes in or 40 minutes into a ride but the connection to my trainer will drop. The last few times it has only happened once during the ride but it’ll be out for for long enough that in a group ride, everyone would have ridden off into the distance.
Hi @GAOFENG_LI It’s great to know that everything is running fine now.
Thank you for trying the workaround suggested. @Andrew_Jones8, If you’d like to continue troubleshooting your specific situation to narrow down where the potential issue is coming from, please write in. zwift.com/contact-us.
I am having the exact same issue as @Andrew_Jones8
Hi @stu_tv, Could you please specify what type of device you’re using? If you’ve received a " connection failure" error, first, you should try using a web browser or program that’s on the same network as Zwift to access the internet. If this doesn’t work, this article still has a few more things to try depending on your specific situation, so proceed accordingly.
Additionally, check on your device if there is any update available. If you need help on how to do it please, review this article.
If the problem persists please, contact our Community Support team—we’re here to help you out!
According to this primer on error messages, Connection Failure relates to communication failure with a paired device, not Internet access. Losing connection to the Zwift servers should be Connection Disconnected. (And these error messages should be clarified so that the failure mode is plainly communicated to the user.)
I’ve now had a connection failure 3 times last 7 days. 2 happened during a race, 1 in the pens. Strangely, done a few Tour de Zwift rides with no issues. Symptoms I have is first random black screens start occurring then a little later connection failure. Happened on both ANT and Bluetooth. Dongle right next to trainer (KICKR V5). Never had any issues whatsoever before this. Has ruined 2 ZRL races for me and my team now. Any help?
this sounds like a graphics error or something, maybe you need to update some drivers?
Another possibility is a performance problem on the PC. I would apply all Windows updates, reboot the PC, reboot the trainer, and watch system performance stats during a ride (Task Manager or whatever you like for monitoring CPU/RAM/GPU/storage). A CPU bound PC can have connection problems.
Don’t think PC hardware is the issue, it has 13th gen i7 CPU and RTX 4060 GPU. Also because it happened both on BLE and ANT that also does not seem the cause. Maybe trainer is dying? But I do find it strange that it worked perfectly in the recent Tour de Zwift rides, but has this issue only in the last 3 races (so not group rides) I did.
during this year I get the message connection failure in most of my rides :-1:
