Hi Dan, I am pleased you have found a workaround for this, but I am still keen to find out why it’s happening, if you don’t ind me bugging you with a few extra questions. Are you using Apple TV 4K or an older version of Apple TV? I assume your firmware is up to date? Have you deleted the Zwift app and reinstalled in? I assume you are on the latest version of Zwift? Is the toggle definitely ON in the ZCA Device Connections tab? Thanks.
+1
I follow and hope that they will fix soon. Same problem with Stryd + Kickr Core 2018. iPad Pro IOS 13.4.
Attila
AppleTV 4k.
I removed the app and reinstalled about a month ago, hoping to solve another problem I had with always being put on the Zwift Carbon bike during the MTB bike challenge they were running that I wasn’t interested in. (it didn’t…)
Everything is up to date on my AppleTV.
I don’t know if the toggle is on, it’s on an iPad out in my workshop, and I can’t get there right now (working).
I experienced this issue yesterday when setting up Zwift on my Apple TV HD, 4th Gen, for the first time.
The connection lock to my Stryd always resulted in ‘No Signal’ to my paired Kickr 1st Gen, the original 2014 model.
When none of the suggested workarounds worked I connected to the Stryd from the Stryd App on my iPhone to prevent Zwift from connecting to it. This resulted in the ‘flickering’ mentioned as Zwift repeatedly tries to connect to the Stryd, which is already connected to another device, and refuses to give up trying to connect. Ended up doing my ride using the Zwift iPad app.
This morning I thought I’d try the faraday cage suggestion and put my Stryd into the small tin case that my Fossil watch came in and put the tin in another room. After restarting the Zwift app on Apple TV, problem solved!
Good news!
This bug I reported on the 20th of October 2018 has finally be fixed! ![]()
I’ve tried to reproduce the bug after the fix and I’m no longer getting this
conflict, the screen no longer flickers!
Well done Zwift ![]()
@EastCoast_MTBer read my post above, I see you’re asking about the pairing issue on AppleTv, here Game Update - April 29th, 2020
Confirmed. Just completed my second ride with no attempts to lock on to my Stryd, disabling my Kickr!
