Why does my dashboard on Zwift companion keep on switching between companion and home page ??? Any help please
Try turning of cell service on the device running the ZCA and see if that helps.
How are both devices connected to your network, wired or wireless? There could be interference with the WiFi and you could try changing the channel that it is using.
They are both running off WiFi Paul
There could be interference, try changing the WiFi channel of just use the 2.4GHz since it has a stronger signal.
Sorry
What do you mean change the channel or just use 2.4 GHz ?
On your router you should be able to change the channel that the WiFi signals use. If possible I would also recommend splitting the 2.4GHz and the 5GHz signals into 2 different SSIDs.
Thank you for your help Paul it’s now working
