I have been using Zwift with my Surface 6 and the companion app on my phone for about 5 years. Sadly my Surface died and my new surface laptop has a snapdragon processor - not supported my Zwift. No worries, I got zwift on my new ipad - but the companion on my phone doesn’t flip over when I am riding, so chatting, switching erg mode, giving ride ons etc much more difficult. Yes the apps are up to date, yes I am on the same wifi network. I’ve been on Zwift support chat for over an hour and am getting nowhere. Help!!
Are you sure you’re on the same wifi network? No chance you have 2.4 and 5 GHz networks with the same name?
100% on same wifi network - we have two and I have toggled back and forth with no joy.
great name BTW
it could be that my router is putting the phone on 2.4 and 5 … but how do I fix for that??
Any chance you’re using a mesh network? I think that there can be issues if the game and Companion devices attach to different nodes. (My setup is pretty basic, so I’m really just regurgitating things I’ve seen mentioned on the Forum. Hopefully someone more technically inclined will pop in soon.)
i do not know what a mesh network is. Claude has been helping. I’ll ask AI and see. usually bumbling around helps. sadly the dude in tech support clearly had never used the companion app. he’s escalated it. I like the app alot. I ahve friends I’ve been cycling with since the pandemic…
To check if they are on different frequency bands, you would need to get into the administrative interface of your WiFi system. The information would be there. If you tell me the make/model of the WiFi device I might be able to find helpful information.
Both of your devices will need to have permission to access the local network. Usually this comes up in a permission prompt when you install the app, so deleting the app and re-installing it can help. If you get any permission prompts when running Zwift or Companion for the first time after re-installing, you will need to allow those things.
On Apple devices with a cellular interface you should also make sure that the WiFi Assist feature is disabled so it can’t switch to cellular data. Or put the device in airplane mode and then enable WiFi manually. If switching to cellular data turns out to be the problem, that is also a sign that your WiFi coverage is poor since it will only do that when the signal is not strong.
Thank you for this. I am going to have some time tomorrow to try this out!
and I’ll check out the Router (aka talk to my husband)
From what I can tell that is a Spectrum cable modem that does not include WiFi services, like a Hitron EN2251. Based on that, my assumption is that you have some other network device that provides WiFi. A router of some kind. All the relevant settings would be in the WiFi device.
Is it just me, or does it also look like it still has the plastic ‘cover’ from the factory over the label? And does it make any difference to remove it (i.e. excess heat in the unit)? Not likely to be what’s causing the issue, but might shorten the life of the modem if it’s getting hot. ![]()
It does look like there is packing film still on the cable modem. I’m doubtful this is important but yes it looks like it’s still there.
