Coloured flickering during group rides in Neokyo
Today I rode a reasonably large group ride (130 riders) in Neokyo for the first time in a while. When riding at the back of the pack, Zwift was almost unwatchable due to huge full-screen coloured fragments that would render for a frame or two, causing horrible flickering.
I am using a late 2014 iMac 27 inch retina display, which has an AMD Radeon R9 M290X graphics processor with 2GB memory. Changing resolution didn’t help, and restarting the game/computer made no difference (I’ve seen this in other similar rides before). I’m using the latest game version at the time of writing.
The problem is clearly related to the number of riders visible at the same time - if you move towards the front of the group, the problem does not occur, and if you use the 1st person camera view, which shows fewer riders than the default, then again the problem diminishes. As I had a 2.5h ride to do, I experimented a bit, and found that if fewer than about 50 riders are visible, then the problem is unlikely to happen, while more than 60 makes it very likely.
I have not seen this issue in other worlds, although I’ve not done large group rides in all of them recently. I have a video taken from my phone showing the issue (it happens 11 times in the 4s footage) although I cannot upload it here. Instead here are a few stills from it.
@shooj is there a bug ID for this? These should be combined to one known issue thread.
After doing another large group ride today, I can confirm that as per the other threads above, the issue is not limited to Neokyo - it also affects Crit City, specifically the final straight to the finish on Downtown Dolphin. At least it’s only part of the course there - Neokyo is horribly unusable in this situation.
Can anyone from Zwift confirm that this issue is at least recognised?
I did the Stage 1 Tour ride today on the Chasing the Sun route. All the bystanders in the city part of the course were either flashing green or yellow. Some weird flashing glitches too during the ride. I am using Apple TV 4K.
I believe this was the most recent update from Zwift
The issue with the bystanders is described in this thread linked below. I don’t know if it’s related to the flickering screen issue - my guess is probably not but I don’t think Zwift have responded to the bug in which bystanders change to the color of a nearby pace partner or holo replay. On my M1 mac I always see the strangely colored bystanders but have never seen the other weird color flashes taking over the display, even in large groups in Neokyo where it seems to be common.
