Circuit
Ja fiz o circuito Roule Ma Poule na FRANCA varias vezes e nao consigo o selo de conclusão. Alguem ja teve essa experiencia?
I’ve done the Roule Ma Poule circuit in FRANCE several times and I can’t get the completion stamp. Has anyone had this experience?
[image]
In the Companion app, under the Leaderboards section, select France and check if you have the green mark next to Roule Ma Poule. If it’s there, then Zwift thinks you’ve completed the route. If not, you may want to check with Zwift support. If you can show them a completed ride for the route they will probably fix the badge for you.
