(I did a search in bugs and known issues and couldn’t find anything but apologies if this is a duplicate/known issue)
I’m getting very blurred/out of focus screenshots since the latest update. Its intermittent / not all photos.
Some are ridiculous, like the focus on the lens is way out, and the rider is just a smudge. I’ve uploaded one example but this has happened several times now. You can see that the map is in-focus/fine, but the in-game shot (the rest of the image) is blurred as if out of focus
EDIT: Things we know so far:
The UI overlays are always clear, the in-game footage is blurrred
Nothing to do with workout “pain” effect (pain effect disabled)
Happens even when Zwift and OS patched to latest version, and hard-restarted
Happens regardless of whether in a workout or free riding
Happens on many (perhaps all) maps including Makuri/Urukazi, Watopia and France
I only ride on iOS and have not seen it. Only possible (but that is not new) thing I can think of is in training sessions where you get that blurry “effort” effect towards the end of harder intervals if you that set on.
Thanks @Oliver_ZRace_Central - is reporting this here sufficient to get it logged as a bug or do I need to bring it to Zwift’s attention some other way?
I have not seen this on iPadOS or TV OS, but don’t use Zwift on a phone so am not sure about iOS. However, it seems very odd that some of the elements are NOT blurred (presumably those parts of the screen that are rendered at a higher resolution than the game itself - basically all of the HUD elements). Have you checked to ensure that you are on the latest iOS/iPadOS/TV OS version, in addition to the latest version of Zwift? And have you tried force-quitting the app to see if a reload corrects the issue?
Yes, I am on the latest version of iOS and of Zwift. I update before every ride. This issue continues to occur across multiple rides across multiple weeks. No offence, but I know what I’m doing and this is not a “user error”.
Its worth pointing out at no point does the screen “look” blurred to me, its an artifact that shows up in screenshots only.
No offence taken. We are just trying to help. There don’t seem to be any other reports of this issue, so it seems more likely that something is not working on your end vs. something being wrong with Zwift. You didn’t mention if you force-quit the app after each use. This seems to ‘solve’ a number of strange issues.
Interesting. You haven’t mentioned on what device you are running Zwift. You’ve said iOS, which would indicate an iPhone, but the screenshots make me think perhaps it’s iPadOS or TVOS. What is your specific device and model?
It is an ipad Pro 12.9 (MHNG3B/A), latest version of operating system. Its technically “iPadOS” for the ipads, used to be called iOS but I think they changed the name at some point, same difference.
When you are seeing the fuzzy photos, is this in the Companion app? Strava? Zwift website? All of the above? I have definitely noted that when viewing photos in the Companion app they can be fuzzy when I first open them, but then they ‘clear up’ after a few seconds.
There are a couple of known issue with screenshots, one specifically crashes Apple devices. Your blurred screenshots may or may not be related to the root causes of these other things for which the fix is coming next week.
In the meantime, I’ll flag up your report. Thanks for the screenshots, as these help us see what’s happening on your end.
@shooj@D.A. Coincidentally enough, I actually ended up having this issue for the first time on my ride this afternoon. A couple of things I noted, the first of which appears to be true for @D.A photos above, also. (The second might be true, but there is not yet enough information to know.)
The photo does not have all of the elements I would expect. In my photo, the watts/cadence/HR window is missing. In the first photo @D.A posted the only element showing is the minimap. And in the second the watts/cadence/HR window is missing.
The second thing is that I had been doing a workout and, when saving my ride, the screenshot with the workout summary (the window that pops up at the end of the workout) was not included in the available photos. And, perhaps interestingly, the blurred photo appears to be from about the time that photo would have been taken. It sort of looks like the program just got confused when trying to take that image. @D.A any chance your blurry photos were taken right at the end of a workout, or some sort of event?
Thanks @shooj appreciate you logging this, let me know if you need more info.
@Nigel_Tufnel good to see the independent verification, again with screenshots, should help confirm/validate this as a real issue for Zwift support! At least I know I’m not imagining it now In terms of the points you make, they’re very valid. (1) UI elements do seem to be missing yes, not sure if this will help Zwift identify cause of the bug, and (2) I do a workout on most of my rides, its hard to say if the screenshots were taken during the workout or afterwards though because of all the missing UI elements as per your first point. However, given that I understand screenshots are taken at “key” moments now, such as taking KOM jerseys, finishing workouts etc then that is certainly plausible. It may also explain why only relatively few people are reporting this issue, if it is limited to screenshots taken at end of workouts only, however I cannot confirm either way.
