Hello there. I have bought a Zwift Ride and the associated trainer (Wahoo Kickr Core). I tried doing a ride in the Android application and I immediately noticed that the gears are not really changing, I mean when I shift to the hardest gear (gear 24) on flat terrain, the resistance is the same as it was with gear 10.
Here’s what I did so far:
- Increase the physical resistance (by turning to 10 - max value - the “wheel” located near the cog)
- Update the firmware of the trainer using the Wahoo app
- Update the firmware of the handlebars using the Companion app
- In the Zwift App, in the settings, section “Hardware”, set the setting “trainer resistance” to the maximal possible value.
Despite doing all this, I’m still stuck with a €1500 trainer that won’t change gears, so I’m a bit angry and frustrated at the moment.
Any tips?
