Avatar Not Moving with KICKR Rollr
I just purchased a Wahoo Kikr Roller
I have set it up and connected all ok
On zwift when I log in I can connect to my roller correctly
But when I start a ride it’s not moving at all
I thought it was maybe I needed to calibrate so I down calibration in zwift app and it worked fine and picking up a reading
I also checked the wahoo app and I connected fine and was getting a reading when I was pedalling
I seen someone saying make sure roller isn’t connected to any other app but I am not, I make sure I’m not connected to wahoo before trying zwift.
I have tried all the reinstalling, turning off and on etc but not getting anywhere.
Any ideas?
The Rollr doesn’t have a power meter and is designed to work with a power meter you already own. Do you have one and have you paired it to the Rollr in the Wahoo app?
https://support.wahoofitness.com/hc/en-us/articles/18236856396178-Pair-a-power-meter-to-a-KICKR-ROLLR
If you don’t have a power meter on your bike, you would have to pair the Rollr as a speed sensor in Zwift since it doesn’t transmit power on its own. When you do it that way the Rollr also does not support terrain simulation or ERG mode.
https://support.wahoofitness.com/hc/en-us/articles/11874201237010-Use-ROLLR-without-a-power-meter-virtual-power
