That’s ok - I spent 5 hours trying to fix it on Friday night and am feeling your pain. It’s definitely a Zwift software issue
This is a Zwift bug that affects 720p HD Ready TVs when you’re running Apple TV. There is a workaround mentioned in the earlier comments, but it doesn’t seem to help everyone.
You should file a support case so they understand that you are affected by this bug, and if you have access to a different display, like a 1080p TV or a computer monitor, that would probably work around it as well.
Appreciate the conversation here. I have the same issue. Everything else runs full screen I will submit a bug report to Zwift.
Please report your problem to Zwfit support.
100% the same problem as I have.
Hope Zwift will fix it asap ![]()
Done. Emailed Zwift support. initial AI support bot forwarded my report to a member of the Zwift team
After days finally Zwift support (or most likely a bot) send me an email with the suggestion to change the HDMI cable…
I´m very dissapointed in the moment
another one with this problem, since latest update. Apple TV, and SOny TV is only HD Ready so can’t do 1080 so is stuck at 720. Pinged Zwift support to get them moving on this
It seems that some 720p HD Ready TVs can downscale a 1080p input, but not all of them can do it. Anyone with this problem should certainly try setting 1080p on the Apple TV, but understand that it might not go anywhere.
The strange thing is, that Apple TV can set any solution on my Tvs without this issue. But Apple TV dont even show me the menue were you could change the solution when its connected with the TV who has the issue.
my TV says “out of range” for 1080p if I set that on apple so no joy there.
(I did take the appleTV inside and try another 4K TV which works fine I’m not allowed my bike in that room!)
Just like me, exactly!
Hello all,
We’re investigating this at Zwift HQ. It seems to be very similar to this issue reported back in 2019 which occurred for folks using 720p displays after updating to tvOS version 13.
I’ll share any updates or helpful workarounds as soon as they become available.
