Hello everybody,
after reinstall Zwift via Apple TV the start screen with the Zwift logo looks normal, but then the picture is only in the left, lower corner. In the past my TV works fine without any problems.
App and apple TV is updated and also a complete new install of Zwift and a reset of the apple tv didnt help.
An older TV woks fine, picture is normal.
Can anybody help me out?
Thank you!
Have you inadvertently activated the picture-in-picture feature of your ATV?
No, because it works completely fine until I stopped for cycling outdoors and now after a reinstall I have this problem.
And I don’t know how do to turn this feature on.
This is one of the surest ways to accidentally turn something on.
It must be a problem with my TV after the Zwift update. With my old TV I can run Zwift without problems, full screen.
All other Apps, e.g. YouTube, runs normal.
That could be true but you can also factory-reset the Apple TV and see if that changes anything
It did a reset, twice. Didn’t help.
So this only happens with the Zwift app, and no other apps on the same ATV? That’s definitely odd.
Have you tried setting the aspect ratio settings on Apple TV?
I would also test with another HDMI cable, and with a different HDMI port on the TV
Yes Nigel, only the Zwift App
I will check that tomorrow. For today I have enough
After a long evening of try and errors, the following:
The problem is my TV, not the AppleTV or the Zwfit app or the latest update.
Because: On any TVs in my house I can switch from 740p to 1080p in HDR or SDR, or what ever AND I have a possibility in ATV → Video settings → “adjust screensize” (hope this is the correct translation, sorry!) and voila! It works at full screen.
But with my newer, bigger Toshiba TV (wich I used since years for my inddor Zwfit sessions!) the Apple TV don´t show my this possibility and I can´t switch up to 1080p?
And I still don´t know why this happens now, as it works perfect for years?
That´s all I can say about it for now. May there will be an update to fix that problem?
I think you may have established that you haven’t activated picture-in-picture mode in Apple TV, but you have not established that the TV itself has not entered its own picture-in-picture mode. I would find the model number of the TV and look for the manual to see if there’s any information about whether it supports that feature and how it’s activated.
My TV hasn´t the PIP function. Everything else, is running normal. Even the start screen of Zwift (blue with white logo) is full screen, all other Apps and the normal TV Programm is full screen
Very interesting that Zwift begins full screen and then switches. You might want to have support look at your log files to see if they can tell what the video mode is once the game is running. Since you’re on Apple TV you have no way to check that yourself.
Do I understand you correctly, that the support can look at my log files to see if there is a problem?
But I still don´t understand why it´s running with full screen on my other TVs? And why it is runnning perfectly for years on this TV and after a reinstall I have such a problem?
Yes your logs are visible to support, but not to you on Apple TV. On anything other than Apple TV you could look at the logs yourself.
I don’t have an explanation for you other than that this TV is different from the others. Zwift could probably tell which video mode the game thinks the TV supports. I don’t know if they can fix that though, or if they will find a game change that caused it.
Thanks a lot Paul!
How can I get in contact with the support team?
support@zwift.com or go to the website and click on support
