Apple TV | Zwift displays in lower left corner of 720p display [October 2026]
Thank you again Paul, I really appriciate that!
I don’t know if this is your issue,or if you’ve already tried this, but I found this online:
To fix a Toshiba TV that displays an app or the entire home screen minimized into a tiny window in the lower left corner, you need to perform a full system restart or a hard power cycle. This is a known resolution bug that frequently impacts Toshiba Smart TVs (especially those running Fire TV or Android software). Turning the TV off with the remote only puts it into standby mode, which fails to clear the system glitch.
Thanks Nigel, I but my older Toshiba 32av501p isn´t a smart TV. But I try to figure out if I can reset this old model as well.
I tried several things, nothing fixed the problem.
After another two days, I think the problem could be that Apple TV automatically switches down to 720p (but why?!?!) and this leads to the small scree in the left corner. When I want to switch the solution up to 1080p, Apple tells me, that it went back to the old solution.
Another strange thing is, that when this TV is connected with the ATV there is no possibility to change the aspect ration, wich is normally under the video settings?!? With all my ather TVs I can do this and fix the problem, as the small screen in the lower, left corner appears there too.?!? Change ration and full screen.
And all that after the reinstall of the Zwift app.
Now I hope Zwift support will answer soon.
Have a nice one!
Let us know how this works out. I have exactly the same problem since yesterday. zwift logo is fine then switches to small screen left corner. I have apple tv and an old samsung 32” 720p. Rebooted everything reinstalled zwift, same problem.
You should also contact Zwift support. More support cases improves the odds that it will be worked on.
This is an identified graphic scaling bug introduced in our latest application release that specifically conflicts with older 720p HD-Ready television resolution profiles on tvOS platforms.
Because the initial launch animation triggers a universal aspect ratio check that scales perfectly, the application client encounters a resolution mismatch immediately afterward when loading the 3D rendering pipeline, causing the entire in-game interface to shrink down to a fraction of its intended size.
To temporarily bypass this layout error while our engineering team develops a hotfix, you can force the client to recalculate its grid coordinates by going into your Apple TV native system menu. Navigate to Settings, select Audio and Video, open the TV Resolution tab, and manually force the output resolution profile to 1080p SDR or 1080p HDR rather than leaving it on “Auto” or “720p”.
Once you have locked the Apple TV system to a 1080p output signal, force-close the Zwift application by double-tapping the TV button on your Siri remote, swipe up to clear the background cache, and relaunch the app; your older Samsung display should automatically downscale the incoming 1080p signal to fill the complete physical viewing boundaries smoothly.
I contacted Zwift two days ago, no answer yet. Maybe I try it again tomorrow.
I have the same porblem.
But the bypass is not possible with my TV. When I try to choose 1080p SDR or 1080p HDR a message appears after some seconds that tells me that ATV puts the seolution on your TV back.
With my older, smaller TV the bypass works as I already wrote here.
Do you know when that hotfix will be available?
They only said they are working on a solution.
Thanks, at least you got an answer.
Hope the best, they fix it
It might just be me, but this sounds like a great excuse to buy a new TV!! :grin:
Nigel, mate, you don’t know my wife…:grimacing:
I never forget her reaction after my 4th roadbike…:flushed_face::oncoming_fist:
After another email, Zwift support answered.
They “escalated” my problem and will let me know when it’s fixed.
Hope that will happen soon…:folded_hands:
Thanks for the info. I am having the same problem
Maybe you could send a email to the Zwift support as well, only to let them know that there more user with that probem.
Yes, I have already. I emailed them when I commented on your thread earlier. So far I have only received a holding response
Try again please. They didnt answer my first mail as well, only received a holding response as well.
They are looking at it. Have given me a whole bunch of stuff to try that I’ve already tried and missing the point that match doesn’t work as the TV, like yours, won’t switch to 1080. I’ve sent them a bunch of screenshots and reiterated what I’ve tried. Just fyi
I really appreciate you afford. Thank you again!:+1:
