I’m fairly new to Zwift but having fun with it so far. I intend to use it for both running and cycling.
I’m having real challenges though with the Apple app, specifically when it comes to switching between a run and ride.
For example, I did a run the other night with no problems. Note that I have a Stryd footpod.
But this morning when I went to do a cycle (I use the Companion app to feed all three bluetooth devices to which in turn feeds to the Apple TV), I could not select a run - it was stuck in the Run mode and trying to pair up my footpod.
At the top of the screen I can use the Apple TV mouse to hover over the Run/Ride section at the top, but no way to toggle between them! It is very frustrating but equally suspect it is something obvious.
I try cycling on the trainer to hopefully enable it to realise I want to do a ride, but it is stuck on a Run.
So my question is, using the Apple TV app, how do you switch between Run and Ride? Is there a shortcut?
In the end I just got frustrated with the Apple TV and hooked up my laptop and managed to get a ride in.
Note that I also uninstalled the Companion app and reinstalled but that did not fix the problem.
Any help or insights would be appreciated.
Thanks,
Aaron
PS I find the Apple TV remote an absolute ball ache as well ![]()
