Hi I have been getting a lot of ANT+ dropouts. Not every time. When it drops out it will not connect again. Happens between 10 - 30 minutes into a race.
Have tried putting ANT+ closer but no difference. Tried restarting the lap top each time but still the drop out occur.
The ANT+ icon still flashed as does the bluetooth but I get NO SIGNAL on the paring screens. This shows on the HRM paring screen too.
The if I repair to use Bluetooth there is a 10 - 15 second delay. If I start to sprint, my avatar and readings dont show up on screen until over 10 seconds later and then when I stop the sprint my avatar and settings are showing the power and everything until 10 or so seconds later.
This happens even if I select Bluetooth at the start instead of using ANT+
Any ideas. Kinda fustrating.
Cheers
Andrew
