Are you saying that you tried to quit and save using the Companion App, and that’s what didn’t work? Did you try to quit and save using the pause menu within the Zwift game?
I Quit and Saved the ride as I normally do, not in the Companion app, but on the desktop App after stopping cycling (pausing) which then allows the MENU to show up in the lower left of the screen. I hit MENU, and then after the ride stats finish summarizing, the SAVE menu (show the Garmin Upload) appears and I hit Save and Upload. But it’s not happening anymore. I disconnected the Garmin connection and reconnected it, but still no automatic uploads.
I just tried a short ride again, just 5 minutes. I quit and saved as normal. However, on the Companion App it is still saying “the activity is still in progress”, and the ride time is continuing to increase even though I clearly ended and saved the ride. The Activity Log on the Zwift.com site continues to uptick for this ride even though I ended the ride some time ago.
The screen upon Save and Quit looks exactly as it aways did: I finish the ride, hit MENU, wait for the ride summary to appear, hit OK at the bottom, a screen appears with the option to Save/Upload/Exit or Trash the ride. I choose Save, and the desktop app immediately closes. The behavior is precisely as it always was, except now, the ride does not stop, nor does it upload to Garmin.
Yes, my app is current with the Drop Shop update.
No, I have not yet uninstalled and reinstalled the Game, nor have I yet deleted the Companion App and re-installed it on my phone.
Also, I tried yet another short ride to see how long it would take for the activity to end if I did nothing and didn’t delete the inprogress.fit file. After about an hour, the Activity ended on it’s own, but it still did not upload to Garmin, and it was not clear if all the ride data was precise on the Zwift Activity Log.
The failure to end the ride is odd. If it continues after you reinstall the game you will want to open a support ticket by emailing support@zwift.com. include a copy of your log files along with a description of your symptoms.
I uninstalled all Zwift applications from all computers and mobile devices. I made sure the uninstall was complete using a 3rd party uninstaller and verified all Zwift files and folders in all directories were gone. Cleaned trash, restarted computer. Reinstalled the Mac application on only one computer and then put the Companion App on one mobile device which I use while riding.
The computer application and companion app are working perfectly, the ride quit when I ended and I was able to save it as normal, so that issue of the ride not ending is behind me for now. All ride data was accurate.
HOWEVER, the ride did not automatically upload to Garmin. Of course, I can easily upload it manually, but it sure was nice having that step occur automatically. I guess I’ll just wait until Zwift technicians and Garmin can resolve the issue.
Windows 10, ant+ all the way.
Tried two trainers. Two sets of hardware (power meters etc.). Tried two different accounts. Tried uninstalling Zwift, clearing the Zwift folder in Documents, even cleaning the Registry (sic!) for everything with Zwift in name. Cleared Internet caches (so that login information is not saved). And yes, tried rebooting.
Tried all above in ALL combinations. I’ve spent a bloody half day on this. Now it’s 1am in the night and I give up.
I have the same problem, today for the first time. I selected save & exit, and now the activity is still ongoing. I use the desktop app on Mac, during the ride I also had the companion app open.
In the app it still says: “Zwifting Now”.
edit: hmm, ok, right after I posted this message I downloaded the .fit file from my.zwift.com because I needed this. When I then checked the companion app again the ride had ended, with the correct duration. Also on my.zwift.com. Coincidence?
I just had this exact same problem. I was doing a custom workout, workout finished and I kept riding until the course I was on completed. I received the badge for “Everything Bagel” in New York and ended the ride, saved and exited. However the companion never recorded anything past the workout and it never ended. Its still active as I write this. Nonetheless I did not get my badge the, the ride never got uploaded to strava. In the end I opted to upload the ride manually, however this behavior really makes me start thinking twice about the integrity of this application.
Same here. Tried on Ipad and Android, same result.
Activity won’t stop after save and quit. Nothing in myzwift. Zwift companion showing “zwifting now”.
A ride needs to be at least 2km to be saved! Otherwise Zwift won’t stop the ride until you cancel it. This solved my problem after just testing my new HR sensor … hope this information helps you!
I’ve just done about 12 0.5km-1.5km rides trying to test near gear and couldn’t figure why it would not save. Just came to this thread and seen this. Thank you
