Zwift will remember what sensors are paired from the last ride you took, did you clear out the selection, unpair the old sensors and search for the new PM?
Is that the same battery that came with it? If so I would suggest replacing it.The app can read it at 99% but that may be incorrect (personal experience).
Thanks Mike, yes I did try that if I recall correctly, but will try again - (you’ve actually given me in the idea of trying it with my macbook’s bluetooth off, so it only has the choice of ant+ via the dongle)
This is a good idea. I always ensure bluetooth is off whilst my ant+ items connect. Once they have hooked up I then put bluetooth back on.
So far so good.
Thanks Troy - i’ve tried a combination of all the above suggestions and got it working.
It’s not entirely glitch free (I’ve found zwift can be a bit temperamental generally sometimes) but a combination of pairing/unpairing, bluetooth on and off and pressing the ANT+ icon repeatedly on the zwift pairing menu page worked!
Thanks everyone for your replies, much appreciated.
