Hi folks
If I am doing zwift training sessions, should I keep the smart trainer on ERG mode or take it off? I find holding a certain wattage on the smart trainer alot more difficult compared to a simple set up.
Hi folks
Leave ERG mode on, it is supposed to be difficult
ERG will keep your power steady, so you don’t need to shift gears.
If you turn ERG off you need to use your gears to keep your power in the correct range, you can also use the INCLINE button to adjust the resistance.
Keep it on then it is ! Thanks folks.
