Thanks, just looking for Zwift examples as reasons to switch to smart trainer
From your explanation it seems that using a power meter when you are just below or above the target might be just as or more effective allowing for the actual work you can produce on that given day?
There is a bias up or down button on the companion app for workouts, you can increase or decrease the interval by 10%. If it is too hard you can decrease by 10%, if that isn’t enough you can skip the rest of the interval.
Smart trainers have other benefits than ERG mode like being able to replicate hill feel on a free ride.
As said above, you can adjust the power too if the target isn’t quite right, and you can turn it off for a bit if you want to be without it.
If you’re staying ‘wheel on’ then it’s not a huge upgrade over a power meter. If you’re looking at wheel off then the ride feel is so much better it’s worth it anyway
If its of any help I use to zwift with a power meter and dumb trainer, changed to a direct drive smart trainer, for me brilliant.
For workouts having that resistance automatically provided in ERG mode is so much better, its the connectivity between the workout and the power requirements. The trainer sets the level required and you just need to match/hold that. It’s doing the controlling for you.
For just riding in Zwift the feedback you get as the resistance increases as you climb makes so much of a difference.
For me riding with a power meter and dumb trainer is like 2D as compared to 3D with a smart trainer.
